Re: [Gdal-dev] how to write out a tiff file using GDAL?
Ivan Lucena
ivan.lucena at pmldnet.com
Fri Dec 4 09:33:16 EST 2009
You can start by looking at the tutorial:
http://gdal.org/gdal_tutorial.html
The section "Using Create()" shows how to create new files.
Other examples in C or C++ can be found at the /apps folder.
Regards.
> -------Original Message-------
> From: cudars <cudars at yeah.net>
> Subject: [Gdal-dev] how to write out a tiff file using GDAL?
> Sent: Dec 04 '09 09:16
> I am quite new to GDAL.
> I want to read a big remote sensing image (tiff file format),do the digital
> image process, then write the result to a tiff file. The program language is
> C++.
> I have finished read in the digital image file and digital image processing.
> As the image file has several bands. I do not know how to write out a tiff
> file.
> Should I use create or createcopy? The gdalenhance source code using
> VRTDataset. In my case, should I use VRTDataset ? I did not understand the
> gdalenhance source code so far.
> Could anyone give me a example to illustrate how to write out a tiff file in
> GDAL?
> Thanks in advanced.
> View this message in context: http://n2.nabble.com/how-to-write-out-a-tiff-file-using-GDAL-tp4112637p4112637.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
