[Gdal-dev] how to write out a tiff file using GDAL?
cudars
cudars at yeah.net
Fri Dec 4 09:49:29 EST 2009
Ivan-5 wrote:
> You can start by looking at the tutorial:
> http://gdal.org/gdal_tutorial.html
> The section "Using Create()" shows how to create new files.
> Other examples in C or C++ can be found at the /apps folder.
> Regards.
>> -------Original Message-------
>> From: cudars <cudars at yeah.net>
>> Subject: [Gdal-dev] how to write out a tiff file using GDAL?
>> Sent: Dec 04 '09 09:16
>> I am quite new to GDAL.
>> I want to read a big remote sensing image (tiff file format),do the
>> digital
>> image process, then write the result to a tiff file. The program
>> language is
>> C++.
>> I have finished read in the digital image file and digital image
>> processing.
>> As the image file has several bands. I do not know how to write out a
>> tiff
>> file.
>> Should I use create or createcopy? The gdalenhance source code using
>> VRTDataset. In my case, should I use VRTDataset ? I did not understand
>> the
>> gdalenhance source code so far.
>> Could anyone give me a example to illustrate how to write out a tiff
>> file in
>> GDAL?
>> Thanks in advanced.
>> View this message in context:
>> http://n2.nabble.com/how-to-write-out-a-tiff-file-using-GDAL-tp4112637p4112637.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
I have read GDAL API Tutorial.
The Tutorial wrote "Once the dataset is successfully created, all
appropriate metadata and raster data must be written to the file. What this
is will vary according to usage, but a simple case with a projection,
geotransform and raster data is covered here."
If I want to write more metadata other than projection, geotransform etc,
What should I do?
I want to keep the original tiff file metadata and add my metadata to the
new create tiff.
View this message in context: http://n2.nabble.com/how-to-write-out-a-tiff-file-using-GDAL-tp4112637p4112847.html
