[gdal-dev] problem with ArcSDE raster (negative values)
bartvde at osgis.nl bartvde at osgis.nl
Tue Dec 8 04:45:25 EST 2009
Hi list,
I've been trying to debug my problem which I originally posted on
mapserver-users here:
http://lists.osgeo.org/pipermail/mapserver-users/2009-November/063706.html
I've debugged the problem to the following part of
frmts/sde/sderasterband.cpp:
    if (bits_per_pixel >= 8) {
        memcpy(pImage, pixels, block_size);
        GByte *p = reinterpret_cast<GByte*>(pImage);
    } else {
The values in the pixels variable are still okay, and contain mostly
negative values as well as 0 (for example -42).
The p variable only contains positive values and 0 values.
Hopefully this will help somebody to pinpoint the problem, as I am not
familiar enough with C++ to solve this.
TIA.
Best regards,
Bart
