[gdal-dev] Re: your mail
Roger Bivand
Roger.Bivand at nhh.no
Thu Dec 10 08:21:26 EST 2009
On Thu, 10 Dec 2009, Even Rouault wrote:
> Roger,
> this is weird indeed as I use daily MSYS on trunk... I'd bet that you have an
> installed version of cpl_string.h in /usr/local/include that corresponds to the
> 1.6.3 version that didn't have the CPLIsUTF8 and CPLForceToASCII symbols. If
> you've done a make install when building 1.6.3 before, it would have gone there.
> And as -I/usr/local/include is before -I/home/s1155/gdal_svn/gdal/port on the
> GCC command line, the old version would be picked up. I'd recommand you to use
> --prefix when you configure to be able easily to switch between different
> versions to avoid installing stuff in "system" directories.
Even,
Thanks, removing the 1.6.3 headers in local/include resolved the problem.
Would re-ordering the directories included be a safety-first policy?
Best wishes,
Roger
> Best regards,
> Even
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
