[gdal-dev] Re: your mail
Roger Bivand Roger.Bivand at nhh.no
Thu Dec 10 08:55:01 EST 2009
On Thu, 10 Dec 2009, Roger Bivand wrote:
> On Thu, 10 Dec 2009, Even Rouault wrote:
>> Roger,
>> this is weird indeed as I use daily MSYS on trunk... I'd bet that you have
>> an
>> installed version of cpl_string.h in /usr/local/include that corresponds to
>> the
>> 1.6.3 version that didn't have the CPLIsUTF8 and CPLForceToASCII symbols.
>> If
>> you've done a make install when building 1.6.3 before, it would have gone
>> there.
>> And as -I/usr/local/include is before -I/home/s1155/gdal_svn/gdal/port on
>> the
>> GCC command line, the old version would be picked up. I'd recommand you to
>> use
>> --prefix when you configure to be able easily to switch between different
>> versions to avoid installing stuff in "system" directories.
> Even,
> Thanks, removing the 1.6.3 headers in local/include resolved the problem.
> Would re-ordering the directories included be a safety-first policy?
A draft Windows binary rgdal package is at:
http://spatial.nhh.no/R/Devel/rgdal_0.6-23.zip
Roger
> Best wishes,
> Roger
>> Best regards,
>> Even
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
