[gdal-dev] ImportError: No module named osgeo
Even Rouault
even.rouault at mines-paris.org
Fri Dec 11 17:04:51 EST 2009
Malanding Jaiteh a écrit :
The Python bindings are not contained in the packages avalaible at
http://download.osgeo.org/gdal/win32/1.6/
That explains the error you get.
However, you can find prebuilt packages with GDAL Python bindings in :
- FWTools : http://fwtools.maptools.org/
- OSGeo4W : http://trac.osgeo.org/osgeo4w/
- Tamas Szekeres daily builts : http://vbkto.dyndns.org/sdk/
> Folks I need help setting up gdal.
> I get the following error when I tried to run the following import line:
> from osgeo import gdal
> error message:
> Traceback (most recent call last):
> File "C:\GIS_TOOLS\Python\GDAL_Geotiff_conversion.py", line 9, in
> <module>
> I recall running the same script months ago the same machine although
> I had a Windows XP x64 on my machine then. Now I have gdawin32-1.6 on
> 32 bit Windows XP Professional Service Pack 3, with the following
> user variables:
> PATH = C:\C:\gdalwin32-1.6\bin
> GDAL_DATA = C:\gdalwin32-1.6\data
> I am running Python 2.5.1 Tk version 8.4
> IDLE version 1.2.1
> I tried without success to physically locate osgeo module either in
> C:\gdalwin32-1.6 or C:\PYTHON 2.5 directories.
> Also is there a way to do text search on the entire gdal-dev archives?
> Malanding Jaiteh
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
