[gdal-dev] ogr vfk and write access
Tamas Szekeres szekerest at gmail.com
Fri Dec 18 09:02:10 EST 2009
Martin,
Does this driver compile on both Windows and Linux platforms? Just by
looking into your repository I don't see a windows makefile for that. I
would require to support both platforms before adding this in trunk. It
would also be reasonable to include some autotest scripts to make sure the
driver is working correctly.
With regards to the commit access, assuming you intend to be the mainainer
of this code and agree with http://trac.osgeo.org/gdal/wiki/rfc3_commiters
I would support this addition.
Best regards,
Tamas
2009/12/18 Martin Landa <landa.martin at gmail.com>
> Hi GDAL developers,
> some months ago I started working on OGR driver for specific Czech
> data format used in cadastre, see [1] for more info. The source code
> is available here [2]. I would like to ask you if there is any chance
> to move VFK driver to the main GDAL/OGR SVN repository. There is no
> dependency, so it could be compiled by default.
> I am also interested to get write access to the main GDAL/OGR
> repository if possible. My name is Martin Landa and I am GRASS
> developer for some years [3]. It would be honest for me to contribute
> also on the GDAL/OGR project. I would focus myself on GRASS and VFK
> driver and later probably more.
> Thanks & best regards, Martin
> [1]
> http://gama.fsv.cvut.cz/~landa/publications/2010/gis-ostrava-2010/paper/landa-ogr-vfk.pdf<http://gama.fsv.cvut.cz/%7Elanda/publications/2010/gis-ostrava-2010/paper/landa-ogr-vfk.pdf>
> [2] http://josef.fsv.cvut.cz/svn/landa/programming/gdal/vfk/
> [3] http://www.ohloh.net/accounts/martinl
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa<http://gama.fsv.cvut.cz/%7Elanda>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091218/fad907e0/attachment-0001.html
