[gdal-dev] ogr vfk and write access
Martin Landa
landa.martin at gmail.com
Fri Dec 18 09:21:29 EST 2009
2009/12/18 Tamas Szekeres <szekerest at gmail.com>:
> Does this driver compile on both Windows and Linux platforms? Just by
> looking into your repository I don't see a windows makefile for that. I
Right, currently there is only GNUMakefile available. Compiled on
Windows with MinGW. Unfortunately I have no MSVC to test. It's my
TODO.
> would require to support both platforms before adding this in trunk. It
> would also be reasonable to include some autotest scripts to make sure the
> driver is working correctly.
Sure. I will do.
> With regards to the commit access, assuming you intend to be the mainainer
> of this code and agree with http://trac.osgeo.org/gdal/wiki/rfc3_commiters
> I would support this addition.
I agree with RFC3.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
