[gdal-dev] ogr vfk and write access
Martin Landa
landa.martin at gmail.com
Fri Dec 18 12:54:28 EST 2009
2009/12/18 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2009/12/18 Tamas Szekeres <szekerest at gmail.com>:
>> Does this driver compile on both Windows and Linux platforms? Just by
>> looking into your repository I don't see a windows makefile for that. I
> Right, currently there is only GNUMakefile available. Compiled on
> Windows with MinGW. Unfortunately I have no MSVC to test. It's my
> TODO.
done in r1311. Untested, I just need to install MSVC on my laptop.
>> would require to support both platforms before adding this in trunk. It
>> would also be reasonable to include some autotest scripts to make sure the
>> driver is working correctly.
> Sure. I will do.
Can you point me to a sample autotest script?
Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
