[gdal-dev] ogr vfk and write access
Even Rouault
even.rouault at mines-paris.org
Fri Dec 18 14:21:40 EST 2009
Martin,
the autotest suite is located here :
http://trac.osgeo.org/gdal/browser/trunk/autotest
I'm not sure which existing script might serve as a reference. You can
have a look at
http://trac.osgeo.org/gdal/browser/trunk/autotest/ogr/ogr_bna.py for a
script that checks both read and write support
Martin Landa a écrit :
> Hi,
> 2009/12/18 Martin Landa <landa.martin at gmail.com>:
>> Hi,
>> 2009/12/18 Tamas Szekeres <szekerest at gmail.com>:
>>> Does this driver compile on both Windows and Linux platforms? Just by
>>> looking into your repository I don't see a windows makefile for that. I
>> Right, currently there is only GNUMakefile available. Compiled on
>> Windows with MinGW. Unfortunately I have no MSVC to test. It's my
>> TODO.
> done in r1311. Untested, I just need to install MSVC on my laptop.
>>> would require to support both platforms before adding this in trunk. It
>>> would also be reasonable to include some autotest scripts to make sure the
>>> driver is working correctly.
>> Sure. I will do.
> Can you point me to a sample autotest script?
> Thanks, Martin
