Re: Re: [gdal-dev] question about georaster and python
gispowerfan
gispowerfan at gmail.com
Sun Dec 20 20:51:55 EST 2009
thanks! but I think that the method you mentioned will depress the performance, for example, when using the python driver.CreateCopy(source, "geor:user/pwd at db,tab,col", <create options>), in fact it will use the gdal_translate function. And the performance of PL/SQL will exceed the gdal_translate. so I want to use cx_Oracle, but I don't know how to use PL/SQL by cx_Oracle.
2009-12-21
gispowerfan
发件人: Ivan
发送时间: 2009-12-21 02:11:53
收件人: gispowerfan
抄送: gdal-dev
主题: Re: [gdal-dev] question about georaster and python
gispowerfan wrote:
> hi list,
> I have a question about georaster and python, it's maybe not related to
> GDAL code directly, but I think it is related question.
> Now I want to connect to ORACLE by cx_Oracle(which is Python interface to ORACLE), I can use cx_Oracle to create table,insert simple data,
> but can't run the image loader pl/sql, do anyone have any idea? I don't know whether or not that some image loader pl/sql can run by cx_Oracle?
> I know that I can use gdal python interface to connect Georaster, but I
> need to test the performance.
> thanks in advance.
> 2009-12-20
> gispowerfan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Example:
>>> from osgeo import gdal
>>> driver = gdal.GetDriverByName("georaster")
>>> source = gdal.Open("example.tif")
>>> target = driver.CreateCopy(source, "geor:user/pwd at db,tab,col", <create options>)
>>> target = None
>>> source = None
That would load the geotiff file to GeoRaster.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091221/809589d7/attachment.html
