[gdal-dev] WMS problem
Even Rouault even.rouault at mines-paris.org
Mon Dec 21 14:13:48 EST 2009
Michele Zanin a écrit :
Michele,
I've created a Trac ticket for the inconsistency between the code and
the documentation. See http://trac.osgeo.org/gdal/ticket/3299
You're welcome to share your files. I think the best way would be for
you to create a WMS page in the wiki and reference it under the "File
formats" paragraph of http://trac.osgeo.org/gdal/wiki/UserDocs. We might
then add a link from the http://www.gdal.org/frmt_wms.html page to the
wiki page.
Best regards,
Even
> Dear friends,
>    I'm playing with the WMS format from GDAL (svn version, 18323).
> Please note it's my first try with WMS, so it is possible i'm missing
> something important.
> I discovered some inconsistencies about documentation and actual
> parameters for the xml config file.
> In the official documentation http://www.gdal.org/frmt_wms.html , the
> layer is selected with the <Layers> tag.
> _ the TileService mini-driver requires <Dataset> (undocumented)
> _ the WorldWind mini-driver requires <Layer> (without the 's', undocumented).
> The affected files are:
> ./frmts/wms/minidriver_worldwind.cpp
> ./frmts/wms/minidriver_tileservice.cpp
> Also, after some try&error (mainly caused by the fact that the right
> SizeX and SizeY are not derivable from GetCapabilities) I came up with
> some working xml config files for accessing interesting WMS (e.g. US
> topo from terraservice, PCN for Italy, BlueMarbleNG worldwind).
> I think someone else did the same effort in the past and someone else
> will do it in the future. In order to avoid other people to waste
> their time, I think we could create a repository of tested config
> file, maybe in the same http://www.gdal.org/frmt_wms.html page. What
> do you think? I'd like to share my files.
> Thank you for your attention,
> michele
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
