[Gdal-dev] ASRP data sets with multiple IMG files
Alans
alan.stratford at goodrich.com
Tue Dec 22 12:13:36 EST 2009
I am having trouble getting GDAL to recognize ASRP IMG files when the
filename ends in anything other than 01.IMG. For example I have a directory
containing the following ASRP files:
U2881301.GEN,
U2881301.GER,
U2881301.IMG,
U2881301.QAL,
U2881301.SOU,
U2881302.IMG.
When i try to generate a shape file to index these ASRP files with the
command:
gdaltindex shapefile.shp *.IMG
GDAL reports:
ERROR 4: '/path/U2881302.IMG' not recognised as a supported file format.
Unable to open /path/U2881302.IMG, skipping.
Does anyone have a workaround for this?
Regards
Alan
View this message in context: http://n2.nabble.com/ASRP-data-sets-with-multiple-IMG-files-tp4204628p4204628.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
