[Gdal-dev] ASRP data sets with multiple IMG files
Even Rouault even.rouault at mines-paris.org
Tue Dec 22 14:17:34 EST 2009
Alan,
this issue was reported as http://trac.osgeo.org/gdal/ticket/3194.
There's a proposed patch in it.
Another workaround (untested) is to copy U2881301.GEN as U2881302.GEN
and U2881301.QAL as U2881302.QAL
Best regards,
Even
Alans a écrit :
> I am having trouble getting GDAL to recognize ASRP IMG files when the
> filename ends in anything other than 01.IMG. For example I have a directory
> containing the following ASRP files:
>   U2881301.GEN,
>   U2881301.GER,
>   U2881301.IMG,
>   U2881301.QAL,
>   U2881301.SOU,
>   U2881302.IMG.
> When i try to generate a shape file to index these ASRP files with the
> command:
>   gdaltindex shapefile.shp *.IMG
> GDAL reports:
>   ERROR 4: '/path/U2881302.IMG' not recognised as a supported file format.
>   Unable to open /path/U2881302.IMG, skipping.
> Does anyone have a workaround for this?
> Regards
> Alan
