[gdal-dev] OGR: Why not GetPoint() under win32?
Iván Sánchez Ortega
ivan at sanchezortega.es
Tue Dec 22 22:34:52 EST 2009
Hi all,
I've been recently learning Python and OGR in order to code ogr2osm. See
http://lists.openstreetmap.org/pipermail/dev/2009-December/017864.html
Problem is, this script doesn't work when in a win32 box. I'm testing it with
FWTools 2.4.6. It runs OK wiht python-gdal 1.6.3 in my Debian box.
"ogrinfo --version" says 1.7.0dev for FWTools, 1.6.3 for the Debian
python-gdal package.
I've hunted down the bug, and it seems that it's because of a mismatch between
the implementations of the wkbLineString class.
See, I'm doing this:
print geometry
print dir(geometry)
Under Debian, I get this:
LINESTRING (459974 4605130,459974 4605130)
['AddGeometry', 'AddGeometryDirectly', 'AddPoint', 'AddPoint_2D',
'AssignSpatialReference', 'Buffer', 'Centroid', 'Clone', 'CloseRings',
'Contains', 'ConvexHull', 'Crosses', 'Destroy', 'Difference', 'Disjoint',
'Distance', 'Empty', 'Equal', 'ExportToGML', 'ExportToJson', 'ExportToKML',
'ExportToWkb', 'ExportToWkt', 'FlattenTo2D', 'GetArea', 'GetBoundary',
'GetCoordinateDimension', 'GetDimension', 'GetEnvelope', 'GetGeometryCount',
'GetGeometryName', 'GetGeometryRef', 'GetGeometryType', 'GetPoint',
'GetPointCount', 'GetPoint_2D', 'GetSpatialReference', 'GetX', 'GetY', 'GetZ',
'Intersect', 'Intersection', 'IsEmpty', 'IsRing', 'IsSimple', 'IsValid',
'Overlaps', 'SetCoordinateDimension', 'SetPoint', 'SetPoint_2D',
'SymmetricDifference', 'Touches', 'Transform', 'TransformTo', 'Union',
'Within', 'WkbSize', '__class__', '__del__', '__delattr__', '__dict__',
'__doc__', '__getattr__', '__getattribute__', '__hash__', '__init__',
'__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__',
'__setattr__', '__setstate__', '__str__', '__swig_destroy__',
'__swig_getmethods__', '__swig_setmethods__', '__weakref__', 'this']
But, under win32 + FWTools, I get this instead:
'Distance', 'Empty', 'Equal', 'ExportToGML', 'ExportToWkb', 'ExportToWkt',
'FlattenTo2D', 'GetArea', 'GetBoundary', 'GetCoordinateDimension',
'GetDimension', 'GetEnvelope', 'GetGeometryCount', 'GetGeometryName',
'GetGeometryRef', 'GetGeometryType', 'GetPointCount', 'GetSpatialReference',
'GetX', 'GetY', 'GetZ', 'Intersect', 'Intersection', 'Overlaps',
'SetCoordinateDimension', 'SetPoint', 'SetPoint_2D', 'SymmetricDifference',
'Touches', 'Transform', 'TransformTo', 'Union', 'Within', 'WkbSize',
'__copy__', '__del__', '__doc__', '__init__', '__module__', '__str__',
'_o', 'thisown']
So, why do I have a GetPoint() method in one implementation but not in the
other?
Cheers,
Iván Sánchez Ortega <ivan at sanchezortega.es>
Your reasoning is excellent -- it's only your basic assumptions that are
wrong.
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091223/11ca4148/attachment.bin
