[gdal-dev] Generating GML from Database - Problem: No decimal
values
Gregor Fikoczek
gregor.fikoczek at wheregroup.com
Tue Feb 10 04:39:12 EST 2009
Hi list,
i got some new
By generating GML from oracle, i first have to set the NLS_LANG-Parameter:
export NLS_LANG=AMERICAN_AMERICA.WE8ISO8859P1
ogrinfo OCI:************* -sql "SELECT * from test_decimal_values"
Layer name: SELECT * from test_decimal_values
Geometry: Unknown (any)
Feature Count: 1
Layer SRS WKT:
(unknown)
COL1: Real (0.0)
COL2: Real (6.4)
OGRFeature(SELECT * from test_decimal_values):0
ID (Integer) = 1
COL1 (Real) = 12.3456
COL2 (Real) = 12.3456
=> So now everythin is fine with the GML from the data source oracle
So I got now only the problem with MySQL and the float column:
MySQL:
col1 float
OGR:
col1 (Real) = 12
col1 (Real) = 12
(Real Value (every column) in the databese: 12.1234)
Any idea?
Best Regards,
Greq
Am Dienstag 10 Februar 2009 10:22:07 schrieb Gregor Fikoczek:
> Hi list,
> i got a problem by generating a GML-File from the Oracle- and MySQL-DB
> using ogr2ogr, so I alway getting in MySQL/oracle instead of a float-value
> an rounded integer-value (mostly 0) without any decimal numbers.
> Some Info:
> Structure MySQL:
> ID smallint(6)
> col1 float
> col2 float(8,4)
> col3 double
> col4 double(8,4)
> col5 decimal(10,0)
> col6 decimal(6,4)
> using ogrinfo/ogr2ogr with MySQL:
> ogrinfo MYSQL:******** -sql "SELECT * from test_decimal_values"
> OGRFeature(sql_statement):3
> ID (Integer) = 3
> col1 (Real) = 12
> col2 (Real) = 12
> col3 (Real) = 12
> col4 (Real) = 12
> col5 (Real) = 12
> col6 (Real) = 12.1234
> c
> => Only the values of column col6 [ decimal(6,4)] are right interprated,
> what about the other decimal value in ogr ????
> => My real column is like the col1-column [float]
> Structure Oracle:
> ID NUMBER(2,0)
> COL1 NUMBER
> COL2 NUMBER(6,4)
> using ogrinfo/ogr2ogr with Oracle:
> ogrinfo OCI:********** -sql "SELECT * from test_decimal_values"
> Feature Count: 1
> Layer SRS WKT:
> (unknown)
> COL1: Real (0.0)
> COL2: Real (6.4)
> ID (Integer) = 1
> COL1 (Real) = 12
> COL2 (Real) = 12.0000
> Real Value (every column) in the databese: 12.3456
> => No column-values are right interprated, so what about the decimal value
> in ogr ????
> => My real column is like the col1-column [NUMBER]
> So is there any option i got to set or a workaround for that problem,
> aspacialy in oracle?
> Best regards,
> Greq
> WhereGroup GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Gregor Fikoczek
> Email: gregor.fikoczek at wheregroup.com
> Fon: +49 (0)228 / 90 90 38 - 25
> Fax: +49 (0)228 / 90 90 38 - 11
> info at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Mit freundlichen Grüßen / Kind regards
Gregor Fikoczek
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
www.wheregroup.com
Komplementärin:
vertreten durch:
