[gdal-dev] Is anyone working on an OGR driver for IDRISI vector
data?
Frank Warmerdam
warmerdam at pobox.com
Mon Feb 16 11:07:27 EST 2009
>> The IDRISI raster format is well represented in GDAL, but OGR doesn't
>> contain the IDRISI vector format. Is anyone working or planning to
>> work on this?
>> If I (at the moment very hypothetically) should think of creating a
>> driver - is there somewhere I could steal the database part from?
>> IDRISI use Access database for storing attributes, and comes in
>> Windows version only.
Sjur,
Assuming this isn't already addressed by Ivan's work, you can model
the access db portion on the PGeo driver (gdal/ogr/ogrsf_frmts/pgeo)
which uses the lower level GDAL ODBC services to access and Access file.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
