[Gdal-dev] gdalwarp changes colortable
acangi
aca at ngi.be
Mon Feb 16 09:13:01 EST 2009
Subscription problem, reposting as requested.
acangi wrote:
> Hello,
> I try to translate colormapped geotiff files from EPSG:31300 to EPSG:3812,
> using
> $ gdalwarp -s_srs EPSG:31300 -t_srs "+proj=lcc +lat_1=49.83333333333334
> +lat_2=51.16666666666666 +lat_0=50.79781500000000 +lon_0=4.359215833333335
> +x_0=649328.0 +y_0=665262.0 +ellps=intl +units=m +no_defs" top250r.tif
> top250r_warp.tif
> Using -t_srs EPSG:3812 gives a "is this a valid coordinate system ?"
> Using -t_srs 3812.prj (file containing the WKT, taken from
> http://spatialreference.org/ref/epsg/3812/ogcwkt/
> http://spatialreference.org/ ) gives a "No translation for Lambert Conic
> Conformal (2SP) to PROJ.4 is known"
> As I couldn't find the PROJ.4 syntax for this SRS, I built it based on
> data from the WKT.
> Coordinates transformation seems to work fine, but my colors are wrong:
> Before : http://n2.nabble.com/file/n2334758/before.jpeg
> After : http://n2.nabble.com/file/n2334758/after.jpeg
> Checking the files with gdalinfo, I see differences :
> Size is 18300, 15000 ==> Size is 18301, 15001
> The projection, the origin and the corner coordinates change like expected
> Pixel Size = (16.666670000000000,-16.666699999999999) ==> Pixel Size =
> (16.666302967680906,-16.666302967680906)
> Metadata:
> AREA_OR_POINT=Area
> TIFFTAG_DOCUMENTNAME=\\backstage\jobcontainer1\symb\map250\tiff\plot_complet.tif
> TIFFTAG_SOFTWARE=Barco Graphics TIFFOut V1.0.2
> TIFFTAG_XRESOLUTION=381
> TIFFTAG_YRESOLUTION=381
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> ==> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:COMPRESSION=LZW INTERLEAVE=BAND ==> Image
> Structure Metadata: INTERLEAVE=BAND
> Band 1 Block=256x256 Type=Byte, ColorInterp=Palette ==> Band 1
> Block=18301x1 Type=Byte, ColorInterp=Palette
> The color table is the same.
> I tried with some more options : -of GTiff -co "PROFILE=GeoTIFF" -co
> "INTERLEAVE=PIXEL" -co "COMPRESS=LZW" -co "TILED=YES" :
> Size is 18300, 15001
> Yet another Pixel Size
> I get the "COMPRESSION=LZW"
> and Band 1 Block=256x256 Type=Byte, ColorInterp=Palette
> ...but the colors are still wrong.
> Any idea how I can change the projection without affecting the colors ?
View this message in context: http://n2.nabble.com/gdalwarp-changes-colortable-tp2334758p2335001.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
