[Gdal-dev] gdalwarp changes colortable
Chaitanya kumar CH
chaitanya.ch at gmail.com
Mon Feb 16 20:22:46 EST 2009
acangi,
Could you check if the after image shows any different colors with
some other image viewer like ImageMagick? OpenEV might not be reading
the color table correctly.
Chaitanya kumar CH.
On Mon, Feb 16, 2009 at 7:43 PM, acangi <aca at ngi.be> wrote:
> Subscription problem, reposting as requested.
> acangi wrote:
>> Hello,
>> I try to translate colormapped geotiff files from EPSG:31300 to EPSG:3812,
>> using
>> $ gdalwarp -s_srs EPSG:31300 -t_srs "+proj=lcc +lat_1=49.83333333333334
>> +lat_2=51.16666666666666 +lat_0=50.79781500000000 +lon_0=4.359215833333335
>> +x_0=649328.0 +y_0=665262.0 +ellps=intl +units=m +no_defs" top250r.tif
>> top250r_warp.tif
>> Using -t_srs EPSG:3812 gives a "is this a valid coordinate system ?"
>> Using -t_srs 3812.prj (file containing the WKT, taken from
>> http://spatialreference.org/ref/epsg/3812/ogcwkt/
>> http://spatialreference.org/ ) gives a "No translation for Lambert Conic
>> Conformal (2SP) to PROJ.4 is known"
>> As I couldn't find the PROJ.4 syntax for this SRS, I built it based on
>> data from the WKT.
>> Coordinates transformation seems to work fine, but my colors are wrong:
>> Before : http://n2.nabble.com/file/n2334758/before.jpeg
>> After : http://n2.nabble.com/file/n2334758/after.jpeg
>> Checking the files with gdalinfo, I see differences :
>> Size is 18300, 15000 ==> Size is 18301, 15001
>> The projection, the origin and the corner coordinates change like expected
>> Pixel Size = (16.666670000000000,-16.666699999999999) ==> Pixel Size =
>> (16.666302967680906,-16.666302967680906)
>> Metadata:
>> AREA_OR_POINT=Area
>> TIFFTAG_DOCUMENTNAME=\\backstage\jobcontainer1\symb\map250\tiff\plot_complet.tif
>> TIFFTAG_SOFTWARE=Barco Graphics TIFFOut V1.0.2
>> TIFFTAG_XRESOLUTION=381
>> TIFFTAG_YRESOLUTION=381
>> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>> ==> Metadata:
>> AREA_OR_POINT=Area
>> Image Structure Metadata:COMPRESSION=LZW INTERLEAVE=BAND ==> Image
>> Structure Metadata: INTERLEAVE=BAND
>> Band 1 Block=256x256 Type=Byte, ColorInterp=Palette ==> Band 1
>> Block=18301x1 Type=Byte, ColorInterp=Palette
>> The color table is the same.
>> I tried with some more options : -of GTiff -co "PROFILE=GeoTIFF" -co
>> "INTERLEAVE=PIXEL" -co "COMPRESS=LZW" -co "TILED=YES" :
>> Size is 18300, 15001
>> Yet another Pixel Size
>> I get the "COMPRESSION=LZW"
>> and Band 1 Block=256x256 Type=Byte, ColorInterp=Palette
>> ...but the colors are still wrong.
>> Any idea how I can change the projection without affecting the colors ?
> View this message in context: http://n2.nabble.com/gdalwarp-changes-colortable-tp2334758p2335001.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
