[gdal-dev] Compiling on RHEL 5
Kyle Shannon ksshannon at gmail.com
Fri Feb 20 11:21:37 EST 2009
That was exactly it, running great now, thanks.
kss
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406)829-6954
kshannon at fs.fed.us
On Thu, Feb 19, 2009 at 12:00 PM, Even Rouault <even.rouault at mines-paris.org
> wrote:
> My guess is that /usr/lib/libexpat.so is a 32bit library. Maybe there's
> a /usr/lib64/libexpat.so on your system ? I'm not sure of the filesystem
> layout of RedHat's 64bit systems.
> If that's the case, use the --with-expat-lib= option of the configure
> script.
> Le Thursday 19 February 2009 17:40:31 Kyle Shannon, vous avez écrit :
> > Hello everyone, I am new(er) to linux and I tried to compile gdal on a
> new
> > workstation running Red Hat Enterprise Linux Server release 5.2.  I ran
> > into an error during compilation:
> > /usr/lib/libexpat.so: could not read symbols: File in wrong format
> > collect2: ld returned 1 exit status
> > make[1]: *** [libgdal.la] Error 1
> > make[1]: Leaving directory `/home/kyle/gdal/gdal-1.6.0'
> > make: *** [check-lib] Error 2
> > I am hoping this is a simple issue where I just have to tell the
> configure
> > script something I missed.  Anyone have any ideas?  thank you.
> > Other stats:
> > RHEL 5.2 64bit
> > gcc 4.1.2
> > Kyle Shannon
> > 5775 Highway 10 W.
> > Missoula, MT 59808
> > (406)829-6954
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090220/a8d573ba/attachment.html
