[gdal-dev] Compiling on RHEL 5
Even Rouault
even.rouault at mines-paris.org
Thu Feb 19 14:00:28 EST 2009
My guess is that /usr/lib/libexpat.so is a 32bit library. Maybe there's
a /usr/lib64/libexpat.so on your system ? I'm not sure of the filesystem
layout of RedHat's 64bit systems.
If that's the case, use the --with-expat-lib= option of the configure script.
Le Thursday 19 February 2009 17:40:31 Kyle Shannon, vous avez écrit :
> Hello everyone, I am new(er) to linux and I tried to compile gdal on a new
> workstation running Red Hat Enterprise Linux Server release 5.2. I ran
> into an error during compilation:
> /usr/lib/libexpat.so: could not read symbols: File in wrong format
> collect2: ld returned 1 exit status
> make[1]: *** [libgdal.la] Error 1
> make[1]: Leaving directory `/home/kyle/gdal/gdal-1.6.0'
> make: *** [check-lib] Error 2
> I am hoping this is a simple issue where I just have to tell the configure
> script something I missed. Anyone have any ideas? thank you.
> Other stats:
> RHEL 5.2 64bit
> gcc 4.1.2
> Kyle Shannon
> Physical Science Technician
> RMRS Fire Sciences Lab
> Fire, Fuels & Smoke - RWU 4405
> 5775 Highway 10 W.
> Missoula, MT 59808
> (406)829-6954
> kshannon at fs.fed.us
> ksshannon at gmail.com
