[gdal-dev] swig error on SVN trunk in python
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 15 22:37:12 EST 2009
Gregory, Matthew wrote:
> Hi all,
> I updated trunk (revision 16087) and rebuilt GDAL. My configuration is
> Windows XP/VC7/Python24/swigwin-1.3.33. I rebuilt the core using
> makegdal71 without issues, but when I do 'nmake /f makefile.vc python'
> from within the swig directory, I get an error message:
> ../include/python\ogr_python.i(999999): Error: Missing #endif for
> conditional starting on line 225
> NMAKE : fatal error U1077: 'C:\swig\swigwin-1.3.33\swig.exe' : return
> code '0x1'
> I note that ../include/python/ogr_python.i was updated on January 9. If
> I
> uncomment lines 225 and 226 (as it was in the prevision revision),
> everything builds fine.
> Given that the error message doesn't seem to fit the python code, I'm
> guessing that I'm doing something incorrectly in my setup. I tried this
> with Python25 with similar results. Any help is appreciated.
Matt,
I believe the "# if" was being treated as a C preprocessor #if directive.
I have committed an extra # in ogr_python.i and this seems to correct the
problem. Thanks for the report.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
