[gdal-dev] aux.xml files
Tue Jan 20 11:28:30 EST 2009
Chris Padwick wrote:
> Howdy,
> I’m using gdal 1.5.2.  Every time I call GDALRasterBand::GetHistogram()
> gdal generates a file with the same name as the image and the extension
> .aux.xml.  This file appears to contain a band by band image histogram
> along with some other information.  On subsequent calls, using the same
> image, gdal appears to be finding the .aux.xml file and reading the
> stats from the file rather than computing them from scratch.
> I understand the rationale for the behavior but it is causing problems
> for me.  How can I disable creation of these files, and/or force
> computation of the stats from scratch every time?
Chris,
You can disable creation of .aux.xml files entirely by setting the
GDAL_PAM_ENABLED configuration variable to the value NO.  The most
common way to do this is in the environment.
eg.
set GDAL_PAM_ENABLED=NO
(on windows)
There are Compute function variants for getting band statistics, and
min/max but I can't seem to find one for histograms.  There ought to
be one.  If you file a ticket, I can add one in trunk if that is helpful.
Of course, you can just write your own histogram computation code.
Best regards,
