[gdal-dev] Open Aerial Map Access via C#
Marcelo Oliveira
moliveira at GEOSTATS.com
Mon Jan 26 09:25:54 EST 2009
Hi There,
I am using the GDAL build that comes with FWTools2.2.6 (GDAL 1.6.0dev)
to try to open OAM ("http://openaerialmap.org/static/ww.xml") using the
C# bindings for GDAL and it throws the following exception:
GDALWMS: Bad projection specified.
The source code that causes the exception to be thrown is :
String filename = "http://openaerialmap.org/static/ww.xml";
Gdal.AllRegister();
Dataset dataSet = Gdal.OpenShared(fileName, 0); <----
However, I can open and extract pieces of this dataset using gdalinfo
and gdal_translate via the command line. Is this a know limitation of
the C# bindings or am I doing something wrong?
Thanks, M
Marcelo Simas Oliveira
GeoStats LP
530 Means St., Ste. 310
Atlanta, Georgia 30318
(404) 588-1004
www.geostats.com
