[gdal-dev] Open Aerial Map Access via C#
Tamas Szekeres
szekerest at gmail.com
Mon Jan 26 10:23:54 EST 2009
Marcelo,
How is your <GDAL_WMS>.. service configuration looking like?
Best regards,
Tamas
2009/1/26 Marcelo Oliveira <moliveira at geostats.com>
> Hi There,
> I am using the GDAL build that comes with FWTools2.2.6 (GDAL 1.6.0dev)
> to try to open OAM ("http://openaerialmap.org/static/ww.xml") using the
> C# bindings for GDAL and it throws the following exception:
> GDALWMS: Bad projection specified.
> The source code that causes the exception to be thrown is :
> String filename = "http://openaerialmap.org/static/ww.xml";
> Gdal.AllRegister();
> Dataset dataSet = Gdal.OpenShared(fileName, 0); <----
> However, I can open and extract pieces of this dataset using gdalinfo
> and gdal_translate via the command line. Is this a know limitation of
> the C# bindings or am I doing something wrong?
> Thanks, M
> Marcelo Simas Oliveira
> GeoStats LP
> 530 Means St., Ste. 310
> Atlanta, Georgia 30318
> (404) 588-1004
> www.geostats.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090126/5a02f7d3/attachment-0001.html
