[gdal-dev] Open Aerial Map Access via C#
Marcelo Oliveira moliveira at GEOSTATS.com
Mon Jan 26 10:46:51 EST 2009
Tamas,
Here is how I specified the source when opening the dataset:
       String filename = "http://openaerialmap.org/static/ww.xml";
       Gdal.AllRegister();
       Dataset  dataSet = Gdal.OpenShared(fileName, 0);
Thanks, M
Marcelo Simas Oliveira
GeoStats LP
530 Means St., Ste. 310
Atlanta, Georgia 30318
(404) 588-1004
www.geostats.com
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Monday, January 26, 2009 10:36 AM
To: Marcelo Oliveira
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Open Aerial Map Access via C#
I just wanted to know how did you specify the <GDAL_WMS> service description XML when opening the dataset. Because the error you mentioned sounds like you have an invalid Projection tag in this file.
Best regards,
Tamas
2009/1/26 Marcelo Oliveira <moliveira at geostats.com>
Here is what the URL returns:
<LayerSet Name="OAM" ShowAtStartup="true" ShowOnlyOneLayers="false">
<ChildLayerSet Name="openaerialmap" ShowAtStartup="false" ShowOnlyOneLayer="true">
<QuadTileSet ShowAtStartup="true">
<Name>openaerialmap</Name>
<Description>OpenAerialMap data.</Description>
<DistanceAboveSurface>0</DistanceAboveSurface>
<BoundingBox>
<West>
<Value>-180.0</Value>
</West>
<South>
<Value>-90.0</Value>
</South>
<East>
<Value>180.0</Value>
</East>
<North>
<Value>90.0</Value>
</North>
</BoundingBox>
<TerrainMapped>false</TerrainMapped>
<ImageAccessor>
<LevelZeroTileSizeDegrees>180.0</LevelZeroTileSizeDegrees>
<NumberLevels>20</NumberLevels>
<TextureSizePixels>256</TextureSizePixels>
<ImageFileExtension>jpeg</ImageFileExtension>
<ImageTileService>
<ServerUrl>http://tile.openaerialmap.org/tiles/</ServerUrl>
<DataSetName>openaerialmap</DataSetName>
</ImageTileService>
</ImageAccessor>
<ExtendedInformation>
<Abstract>SRS:EPSG:4326</Abstract>
</ExtendedInformation>
</QuadTileSet>
</ChildLayerSet>
</LayerSet>
GeoStats LP
(404) 588-1004
www.geostats.com
Sent: Monday, January 26, 2009 10:24 AM
Marcelo,
How is your <GDAL_WMS>.. service configuration looking like?
Best regards,
Tamas
Hi There,
I am using the GDAL build that comes with FWTools2.2.6 (GDAL 1.6.0dev)
to try to open OAM ("http://openaerialmap.org/static/ww.xml") using the
C# bindings for GDAL and it throws the following exception:
GDALWMS: Bad projection specified.
The source code that causes the exception to be thrown is :
       Gdal.AllRegister();
       Dataset  dataSet = Gdal.OpenShared(fileName, 0); <----
However,  I can open and extract pieces of this dataset using gdalinfo
and gdal_translate via the command line.  Is this a know limitation of
the C# bindings or am I doing something wrong?
Thanks, M
GeoStats LP
(404) 588-1004
www.geostats.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090126/355b3e84/attachment.html
