[gdal-dev] Open Aerial Map Access via C#
Tamas Szekeres
szekerest at gmail.com
Mon Jan 26 11:45:19 EST 2009
I wonder how this URL is mapped to the WMS driver by default.
For a valid WMS connection string please refer to:
http://www.gdal.org/frmt_wms.html
This URL is reported by gdalinfo as:
gdalinfo http://openaerialmap.org/static/ww.xml
ERROR 4: `/vsimem/http/02802DC8.dat' not recognised as a supported file
format.
ERROR 4: `/tmp/02802DC8.dat' not recognised as a supported file format.
gdalinfo failed - unable to open 'http://openaerialmap.org/static/ww.xml'.
Best regards,
Tamas
2009/1/26 Marcelo Oliveira <moliveira at geostats.com>
> Tamas,
> Here is how I specified the source when opening the dataset:
> String filename = "http://openaerialmap.org/static/ww.xml";
> Gdal.AllRegister();
> Dataset dataSet = Gdal.OpenShared(fileName, 0);
> Thanks, M
> Marcelo Simas Oliveira
> GeoStats LP
> 530 Means St., Ste. 310
> Atlanta, Georgia 30318
> (404) 588-1004
> www.geostats.com
> *From:* Tamas Szekeres [mailto:szekerest at gmail.com]
> *Sent:* Monday, January 26, 2009 10:36 AM
> *To:* Marcelo Oliveira
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Open Aerial Map Access via C#
> I just wanted to know how did you specify the <GDAL_WMS> service
> description XML when opening the dataset. Because the error you mentioned
> sounds like you have an invalid Projection tag in this file.
> Best regards,
> Tamas
> Here is what the URL returns:
> <LayerSet Name="OAM" ShowAtStartup="true" ShowOnlyOneLayers="false">
> <ChildLayerSet Name="openaerialmap" ShowAtStartup="false"
> ShowOnlyOneLayer="true">
> <QuadTileSet ShowAtStartup="true">
> <Name>openaerialmap</Name>
> <Description>OpenAerialMap data.</Description>
> <DistanceAboveSurface>0</DistanceAboveSurface>
> <BoundingBox>
> <West>
> <Value>-180.0</Value>
> </West>
> <South>
> <Value>-90.0</Value>
> </South>
> <East>
> <Value>180.0</Value>
> </East>
> <North>
> <Value>90.0</Value>
> </North>
> </BoundingBox>
> <TerrainMapped>false</TerrainMapped>
> <ImageAccessor>
> <LevelZeroTileSizeDegrees>180.0</LevelZeroTileSizeDegrees>
> <NumberLevels>20</NumberLevels>
> <TextureSizePixels>256</TextureSizePixels>
> <ImageFileExtension>jpeg</ImageFileExtension>
> <ImageTileService>
> <ServerUrl>http://tile.openaerialmap.org/tiles/</ServerUrl>
> <DataSetName>openaerialmap</DataSetName>
> </ImageTileService>
> </ImageAccessor>
> <ExtendedInformation>
> <Abstract>SRS:EPSG:4326</Abstract>
> </ExtendedInformation>
> </QuadTileSet>
> </ChildLayerSet>
> </LayerSet>
> GeoStats LP
> (404) 588-1004
> www.geostats.com
> *Sent:* Monday, January 26, 2009 10:24 AM
> Marcelo,
> How is your <GDAL_WMS>.. service configuration looking like?
> Best regards,
> Tamas
> Hi There,
> I am using the GDAL build that comes with FWTools2.2.6 (GDAL 1.6.0dev)
> to try to open OAM ("http://openaerialmap.org/static/ww.xml") using the
> C# bindings for GDAL and it throws the following exception:
> GDALWMS: Bad projection specified.
> The source code that causes the exception to be thrown is :
> Gdal.AllRegister();
> Dataset dataSet = Gdal.OpenShared(fileName, 0); <----
> However, I can open and extract pieces of this dataset using gdalinfo
> and gdal_translate via the command line. Is this a know limitation of
> the C# bindings or am I doing something wrong?
> Thanks, M
> GeoStats LP
> (404) 588-1004
> www.geostats.com
> gdal-dev mailing list
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090126/0080e201/attachment-0001.html
