[gdal-dev] Merge features from two different files.
Félix Pedrera García
felix.pedrera at deimos-space.com
Mon Jan 26 12:54:01 EST 2009
Hello,
We have several Mapinfo Files with the same geometry information but
with different features associated:
1.TAB
2.TAB
N.TAB
COMMON.TAB
COMMON.TAB covers all the surface from 1.TAB to N.TAB, and are made of
polygons, so a polygon present in 1.TAB has an associated polygon with
the same coordinates in COMMON.TAB, and the same for the files from 1 to N.
1 to N files have one feature named "Value" and in COMMON the feature is
named "Text".
We want to append the "Text" feature in COMMON to every file 1,2,..N,
for each polygon in 1,2,..,N file which overlaps with the polygon with
Is there a way to achieve this with the OGR tools (ogr2ogr) or a better
approach is to load the files in PostGIS and deal with spatial queries?
Maybe using the OGR API or other programming APIs?
Thanks in advance,
Félix
