[gdal-dev] Use an existing image for projection
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 26 11:51:18 EST 2009
Smith, Michael wrote:
> Related to my previous post, is there simply a way to specify an
> existing image as the template for projection? My problem is that the
> SID files I received are all in the same projection, yet some have the
> projection info encoded and others don't. This causes problems as I
> make mosaics with gdalwarp. If I could do something like "-t_srs
> image1.sid" that would be great. Can I get projection out of gdalinfo
> somehow and into a file?
Michael,
I do not plan to extend the -t_srs and related switch to support using
a raster file as a template. However, you can cut and paste the coordinate
system reported by gdalinfo and put it in a text file, then use the name of
this text file as an argument to -t_srs and other similar commandline
switches.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
