[gdal-dev] ECW/ERS projections
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 28 00:47:25 EST 2009
Pinner, Luke wrote:
> Hi
> What is the best way to enable support for ECW/ERS projections that do
> not have an entry in the GDAL_DATA/ecw_cs.wkt dictionary?
> This projection definition is used by multiple people in my area, either
> using the gdal utilities or as part of scripts coded using the gdal
> python api.
> I can manually update the ecw_cs.wkt file on my own installation and add
> the name & wkt (which works fine) but I'd not have to maintain
> modifications to core files over multiple installs.
Luke,
That is pretty much my suggestion for how to handle it. Is this a
coordinate system that you added locally to ERMapper too? Or is it
something supported by more recent ERMapper releases, but missing in GDAL?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
