[gdal-dev] Terra-SAR COSAR data ingestion
Philippe Vachon
philippe at cowpig.ca
Wed Jan 28 14:05:21 EST 2009
Hi Vali,
Have you tested this using GDAL trunk? I only had access to a limited
number of TerraSAR-X scenes when writing the GDAL file reader for it, so
it's possible that the high resolution spotlight imagery is structured
differently and thus can't be read by GDAL.
Could you run the gdalinfo tool on the image you're trying to open and
send me a log? That'd give me a better feel for what is going on.
Cheers,
Phil
On Wed, Jan 28, 2009 at 10:22:12AM -0800, Vali Poncos wrote:
> Hello folks,
> I am starting a development project that involves Terra-SAR X High
> Resolution Spotlight data. I used Frank's FWTools and I can load the data
> but it doesn't seem to contain the georeference information. Also I tried
> the OpenEV from Vexcel which doesn't recognize Terra-SAR data at all. I'll
> try to recompile OpenEV with the latest GDAL in order to be able to load
> the TSX data but I'm concerned about the missing georeferencing
> information. I've seen a posting in this list that indicates GDAL reading
> the XML file coming with TSX.
> My question: is GDAL capable of reading the georeference info for TSX? If
> yes, that means both the FWTools and OpenEV should be updated to load and
> display georeferenced TSX data?
> Thanks,
> Vali
> Yahoo! Canada Toolbar : Search from anywhere on the web and bookmark your
> favourite sites. Download it now!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
