[gdal-dev] GDAL in Netbeans IDE
Ivan Lucena ivan.lucena at pmldnet.com
Thu Jan 29 00:40:02 EST 2009
Hi Vali,
On NetBeans 6.5 you select:
Main Form:
    File/New Project
New Project wizard dialog:
    1. Choose Project
       Category: C/C++
       Projects: C/C++ Project From Existing Code
       Click on "Next>"
    2. Build Tool:
       Select "Using existing makefile"
       Browse or type the full path for the main GNUmakefile
       or:
       Select "Using a makefile generate by a 'configure' script
       Note: I never used that options since I already run ./configure
             from the command line but that could a a good way to go too.
    3. Build actions:
       Working Directory: <main GDAL folder path>
       Build command: make
       Clean command: make clean
    4. Source files:
       Click on "Add Folder: <main GDAL folder path>
    5. Code assistance configuration:
       Select "Automatic configuration"
    6. Project Name and location
       Note: Those path doesn't need to be GDAL folder path
That is it.
Best regards,
Ivan
Vali Poncos wrote:
> Hello,
> Does anybody know how to import the GDAL projects in Netbeans IDE 6.1?
> Is there another IDE used to compile GDAL?
> Thanks,
> Vali
> Now with a new friend-happy design! Try the new *Yahoo! Canada
> Messenger* <http://ca.beta.messenger.yahoo.com/>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
