[gdal-dev] GDAL in Netbeans IDE
Mateusz Loskot mateusz at loskot.net
Sat Jan 31 14:17:43 EST 2009
Iva,
I've taken the liberty to post your notes on the Wiki:
http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithNetBeansIDE
I hope you don't mind.
Best regards,
Mateusz
Ivan Lucena wrote:
> Hi Vali,
> On NetBeans 6.5 you select:
> Main Form:
>     File/New Project
> New Project wizard dialog:
>     1. Choose Project
>        Category: C/C++
>        Projects: C/C++ Project From Existing Code
>        Click on "Next>"
>     2. Build Tool:
>        Select "Using existing makefile"
>        Browse or type the full path for the main GNUmakefile
>        or:
>        Select "Using a makefile generate by a 'configure' script
>        Note: I never used that options since I already run ./configure
>              from the command line but that could a a good way to go too.
>     3. Build actions:
>        Working Directory: <main GDAL folder path>
>        Build command: make
>        Clean command: make clean
>     4. Source files:
>        Click on "Add Folder: <main GDAL folder path>
>     5. Code assistance configuration:
>        Select "Automatic configuration"
>     6. Project Name and location
>        Note: Those path doesn't need to be GDAL folder path
> That is it.
> Best regards,
> Ivan
> Vali Poncos wrote:
>> Hello,
>> Does anybody know how to import the GDAL projects in Netbeans IDE 6.1?
>> Is there another IDE used to compile GDAL?
>> Thanks,
>> Vali
>> Now with a new friend-happy design! Try the new *Yahoo! Canada
>> Messenger* <http://ca.beta.messenger.yahoo.com/>
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Mateusz Loskot
http://mateusz.loskot.net
