[gdal-dev] can java use the jdal
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 7 09:25:08 EDT 2009
maven apache wrote:
> I wonder if there is a java librariy which can be directly used to
> handle the data instead of using the Runtime to call the command(for
> example glalinfo......)?
Maven,
The GDAL project includes java bindings for the api so it should be
practical to recreate pretty much any of the commandline programs
in Java. There is already an example for gdalinfo.
http://trac.osgeo.org/gdal/wiki/GdalOgrInJava
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
