[gdal-dev] can java use the jdal
maven apache apachemaven0 at gmail.com
Tue Jul 7 07:38:13 EDT 2009
I wonder if there is a java librariy which can be directly used to handle
the data instead of using the Runtime to call the command(for example
glalinfo......)?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090707/3b5c205f/attachment.html
