[gdal-dev] gdalwarp and Molleweide projections
Even Rouault even.rouault at mines-paris.org
Wed Jul 8 14:07:07 EDT 2009
I would also note that the Geotiff driver/libgeotiff don't handle Molleweide
projection. (In GDAL trunk, the projection is written as an ESRI PE String
with the full WKT string, so if you only use GDAL trunk, you won't notice any
problem when reading back the projection)
But this is a different problem than the image having artifacts.
