[gdal-dev] How do I open vector files (e.g. shp) using GDAL
Martin Chapman
chapmanm at pixia.com
Mon Jul 20 17:50:33 EDT 2009
Sorry, the call GDALOpen will not work for shape files:
Use
OGRRegisterAll();
dataSource = OGRSFDriverRegistrar::Open((const char*) filePath.c_str());
for c++;
and
hDS = OGROpen
<http://www.gdal.org/ogr/ogr__api_8h.html#123bb02ac8c5cfe143e132f627531125>
( "point.shp", FALSE, NULL );
for c.
see http://www.gdal.org/ogr/ogr_apitut.html for more info
Martin
From: Martin Chapman [mailto:chapmanm at pixia.com]
Sent: Monday, July 20, 2009 3:48 PM
To: 'Smart, Gary'; 'gdal-dev at lists.osgeo.org'
Subject: RE: [gdal-dev] How do I open vector files (e.g. shp) using GDAL
Call OGRRegisterAll(); on the line right before GDALOpen();
Martin
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Smart, Gary
Sent: Monday, July 20, 2009 2:51 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] How do I open vector files (e.g. shp) using GDAL
I understand that GDAL can open vector formats as if they were a dataset?
E.g. I read that it is possible to pass the GDALOpen either a single .shp
file (in which case it treats it as if it only had one layer) or a directory
containing multiple .shp files - which presumably it opens as multi layered?
However, whenever I try to open vector files in this way (directory or file)
I get.
ERROR 4 - blah blah is not recognised as a supported file format"
I am still new to all this (having only just conquered raster formats) so I
suspect I am doing something pretty dumb.
Perhaps someone can help?
Gary
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090720/5f5e3af5/attachment.html
