[gdal-dev] /vsigzip/ write support in trunk
Frank Warmerdam
warmerdam at pobox.com
Mon Jul 20 20:16:37 EDT 2009
Folks,
I have extended Even's /vsigzip/ driver in trunk to support writing as
well as reading. This means it is possible to write a file in compressed
format by using a filename like /vsigzip/out.asc.gz. Note that the /vsigzip/
write driver does not support seeking around in the output stream so only
output drivers that use VSI*L *and* that do not do seeks will work. So it
can't be used for GeoTIFF, but can be used for formats like AAIGRID.
I implemented this primarily so that the new R driver could directly create
a compressed object file.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
