[gdal-dev] Extract BIGTiff libraries from GDAL source package
Enrico Sartorello
enrico.sartorello at gmail.com
Sat Jul 25 09:14:11 EDT 2009
Another question: i've succesfully install BIGTiff from cvs using the usual
configure-make-make install process.
But how can i install the header files as well? I've looked on the Makefile
but can't understand if there's a particular directive to use.
Thanks in advance,
On Fri, Jul 24, 2009 at 1:40 PM, Enrico Sartorello <
enrico.sartorello at gmail.com> wrote:
> Hi Frank and David,
> thank you very much for your informations.
> As you've correctly told, my searches on Google lead me thinking that the
> Aperio distribution was the right side to get BIGTiff libraries.
> Now everything is clear to me, thanks for your clarification!
> Best regards,
> On Fri, Jul 24, 2009 at 3:12 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
>> David Burken wrote:
>>> Enrico,
>>> I like to build straight from cvs:
>>> cvs -d :pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot co
>>> libtiff
>> Enrico,
>> I concur with Dave. The best place to get the latest libtiff4 with
>> bigtiff support is CVS. Please note that the Aperio code is a distinct
>> fork of libtiff and not supported or encouraged for use by the core
>> libtiff maintainers (ie. me). It is unfortunate that it places well on
>> a BigTIFF google search as it has lead several folks astray, including
>> at least one sizable commercial organization who helped fund the
>> official libtiff BigTIFF port!
>> Best regards,
>> On 07/23/2009 04:56 AM, Enrico Sartorello wrote:
>>>> Hi all,
>>>> i need to have a correct BIGTiff package for using it in a program i've
>>>> written in C.
>>>> As far as i can see, the bigtiff package distributed on
>>>> http://www.aperio.com/bigtiff/ is old and can't be correctly compiled,
>>>> so i thought i would get it from GDAL.
>>>> I've seen that BIGTiff is under gdal/frmts/gtiff/libtiff, and i'm even
>>>> able to make it separately from the rest of GDAL.
>>>> But make just create a bunch of *.o files from the sources on that dir
>>>> and nothing more i can use to replace a normal libtiff installation.
>>>> What do i have to do to get my ready-to-use BIGTiff distribution?
>>>> Thanks in advance
>>>> Enrico Sartorello
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
>> and watch the world go round - Rush | Geospatial Programmer for Rent
> Enrico Sartorello
Enrico Sartorello
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090725/56be8bff/attachment-0001.html
