[gdal-dev] Extract BIGTiff libraries from GDAL source package
    Enrico Sartorello
    enrico.sartorello at gmail.com
    Fri Jul 24 07:40:45 EDT 2009
Hi Frank and David,
thank you very much for your informations.
As you've correctly told, my searches on Google lead me thinking that the
Aperio distribution was the right side to get BIGTiff libraries.
Now everything is clear to me, thanks for your clarification!
Best regards,
On Fri, Jul 24, 2009 at 3:12 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> David Burken wrote:
>> Enrico,
>> I like to build straight from cvs:
>> cvs -d :pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot co libtiff
> Enrico,
> I concur with Dave.  The best place to get the latest libtiff4 with
> bigtiff support is CVS.  Please note that the Aperio code is a distinct
> fork of libtiff and not supported or encouraged for use by the core
> libtiff maintainers (ie. me).  It is unfortunate that it places well on
> a BigTIFF google search as it has lead several folks astray, including
> at least one sizable commercial organization who helped fund the
> official libtiff BigTIFF port!
> Best regards,
>  On 07/23/2009 04:56 AM, Enrico Sartorello wrote:
>>> Hi all,
>>> i need to have a correct BIGTiff package for using it in a program i've
>>> written in C.
>>> As far as i can see, the bigtiff package distributed on
>>> http://www.aperio.com/bigtiff/ is old and can't be correctly compiled,
>>> so i thought i would get it from GDAL.
>>> I've seen that BIGTiff is under gdal/frmts/gtiff/libtiff, and i'm even
>>> able to make it separately from the rest of GDAL.
>>> But make just create a bunch of *.o files from the sources on that dir
>>> and nothing more i can use to replace a normal libtiff installation.
>>> What do i have to do to get my ready-to-use BIGTiff distribution?
>>> Thanks in advance
>>> Enrico Sartorello
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Enrico Sartorello
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090724/5a6cdec5/attachment-0001.html
