[gdal-dev] Error in GDAL compiling with HDF4
Wed Jul 29 16:40:40 EDT 2009
Limei Ran wrote:
> checking for FMEObjects... no
> checking for SDreaddata in -lmfhdf... no
> checking for SDreaddata in -lhdf4... no
> configure: error: HDF4 support requested with arg
> "/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/HDF4.2r4/local",
> but neither hdf4 nor mfhdf lib found
> I compiled HDF4 with: --disable-netcdf --disable-fortran and I did not
> compile GDAL with netcdf.  When I got rid of HDF4 in gdal configure, the
> configuration went through.
> The config.log has a lot of errors related to conftest.c like:
> Could you tell me what went wrong in this gdal compiling with hdf4 ?
Limei,
I think you need to find the part of the config.log that relates to hdf to
find out what went wrong.  I think one common problem is building the HDF
library without -fPIC.
You might also check:
  http://trac.osgeo.org/gdal/wiki/HDF
and consider updating it if you learn something likely to be of broader use.
Best regards,
