[gdal-dev] Error in GDAL compiling with HDF4
Limei Ran
lran at unc.edu
Thu Jul 30 11:22:37 EDT 2009
Hi Frank:
I tried setting -fPIC based on the web site. But, it failed as well. I
checked config.log file and it has errors like:
/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/HDF4.2r4/local/lib/libdf.a(cszip.o):
In function `HCIcszip_term':
cszip.c:(.text+0x2ae): undefined reference to `SZ_BufftoBuffCompress'
It appears that szip is causing the problem. I compiled HDF5 and HDF4
with szip-2.1. After I compiled HDF4 without szip. GDAL compiling
worked.
But, I am wondering whether I have to compile HDF5 and HDF4 with szip to
be used in GDAL.
Thank you,
Limei
Frank Warmerdam wrote:
> Limei Ran wrote:
>> checking for FMEObjects... no
>> checking for SDreaddata in -lmfhdf... no
>> checking for SDreaddata in -lhdf4... no
>> configure: error: HDF4 support requested with arg
>> "/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/HDF4.2r4/local",
>> but neither hdf4 nor mfhdf lib found
>> I compiled HDF4 with: --disable-netcdf --disable-fortran and I did
>> not compile GDAL with netcdf. When I got rid of HDF4 in gdal
>> configure, the configuration went through.
>> The config.log has a lot of errors related to conftest.c like:
>> Could you tell me what went wrong in this gdal compiling with hdf4 ?
> Limei,
> I think you need to find the part of the config.log that relates to
> hdf to
> find out what went wrong. I think one common problem is building the HDF
> library without -fPIC.
> You might also check:
> http://trac.osgeo.org/gdal/wiki/HDF
> and consider updating it if you learn something likely to be of
> broader use.
> Best regards,
