[gdal-dev] GDAL 1.6.2 RC1 Released
Even Rouault even.rouault at mines-paris.org
Fri Jul 31 14:25:36 EDT 2009
Howard,
I'm afraid you will have to make a RC2 : gcore/gdal_version.h hasn't been
updated.
Even
Le Friday 31 July 2009 16:08:02 Howard Butler, vous avez écrit :
> All,
> The GDAL team is pleased to announce the release of GDAL 1.6.2 RC1.
> * http://download.osgeo.org/gdal/gdal-1.6.2-RC1.tar.gz
> * http://download.osgeo.org/gdal/gdal162-RC1.zip
> The following issues were addressed in this release:
> General:
>   * OGR expression parser causes access violations with large
> expressions (#2996)
>   * OGR cannot open/handle .DBF files > 2 GB (#3011)
>   * crash in cpl_vsil_win32.cpp when compiling as x64 under Windows
> (#3035)
>   * create index sql execute problem (#3044)
>   * GTiffDataset::FlushCache() cause crashes when used just after
> dataset creation (#3067)
>   * GDALDefaultOverviews::BuildOverviews() causes out-of-bounds writes
> for a 1x1 dataset (#3069)
>   * gdaladdo crashes on a 16-bit dataset when external overviews are
> requested to have JPEG compression (#3070)
>   * Corrupt EXIF info can cause stack buffer overflow in JPEG driver
> (#3078)
> GDAL:
>   * GenBin driver problems (#2730)
>   * Additional dependency to libgdal.so added during linking in gdal/
> apps (#2970)
>   * This NITF Can not be opened (endless loop) with recent GDAL (#3001)
>   * This NITF Can not be opened (endless loop) with recent GDAL (#3002)
>   * PPM Driver 16bit Support Byte Order Decision Questionable (#3012)
>   * GDAL changes projection parameter values (#3017)
>   * bad reading of AAIGRID dataset whose last line doesn't have a
> linebreak character (#3022)
>   * HDF5 Subdataset Issue (#3024)
>   * jp2kak driver can't display this unsigned 16 bit J2K image (#3027)
>   * NITF PRJPSB TRE handling wrong for Transverse Mercator (#3029)
>   * gdaladdo not producing correct overviews for greyscale+alpha image
> (#3033)
>   * GDALLoadRPB/IMDFile fails with path (#3047)
>   * Setting stats and histogram to JP2 compressed NITF corrupts the
> aux.xml (#3051)
>   * poBand->SetMetadataItem( "source_0", szFilterSourceXML,
> "vrt_sources" ) not supported as expected (#3052)
>   * gdaladdo fails with JPEG YCBCR when interleaving is not specified
> to be pixel (#3064)
>   * georaster - NLS problem with XML metadata (#3066)
>   * gdalwarp can crash when reprojecting into an irrelevant SRS (#3079)
> OGR:
>   * Relax KML driver about xmlns (#3004)
>   * KML driver painfully slow when reading huge geometries (#3005)
>   * PG driver does not recognize 'real' data type (#3006)
>   * X-Plane reader: Bezier curves in Pavement and APTLinefeature not
> curved (#3030)
> OGR Spatial References:
>   * Mercator with scale=1 at non-equatoral latitude handled
> improperly. (#3026)
>   * Hotine Oblique Mercator translation to PROJ.4 format looses scale
> factor. (#3032)
>   * Equidistant Conic ESRI Morphing Broken (#3086)
> Python:
>   * OGRFeature.SetField segfault (#3000)
> .NET:
>   * C# Osr.GetProjectionMethodParameterList / OPTGetParameterList
> Access Violation (#3018)
>   * [PATCH - C#] Dataset.ReadRaster()/WriteRaster() doesn't work on
> multi-band datasets (#3073)
> If no significant issues are identified, a PSC vote will be called for
> to promote this RC to final on Wednesday or Thursday next week.
> Howard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
