[gdal-dev] _osr TransformPoint error
Even Rouault
even.rouault at mines-paris.org
Wed Jun 10 17:45:29 EDT 2009
From the error message, it looks like you would need to specify the z
coordinate. tr.TransformPoint(pt[0], pt[1], 0)
But both old gen and new gen python bindings have z coordinate as an optional
argument. I have tested that it works with current trunk.
--> Looks like your OpenEV uses an unofficial/uncommon/old version of the new
gen bindings. because the osr.py file provided with FWTools uses old gen
bindings...
Weird
Le Wednesday 10 June 2009 23:19:12 Gong, Shawn (Contractor), vous avez écrit :
> hi list,
> I've been getting the following error from osr.py:
> File "C:\iapro\OpenEV\python\lib\site-packages\osgeo\osr.py", line 618,
> in TransformPoint return
> _osr.CoordinateTransformation_TransformPoint(*args)
> NotImplementedError: Wrong number of arguments for overloaded function
> 'CoordinateTransformation_TransformPoint'. Possible C/C++ prototypes are:
> TransformPoint(double [3])
> TransformPoint(double [3], double, double, double)
> The function I'm calling is below. I've tried it with different input
> combinations, but I always get the same result.
> tr = osr.CoordinateTransformation(ref, proj)
> tr_pts = []
> for pt in geo_nodes:
> tr_pts.append(tr.TransformPoint(pt[0], pt[1]))
> Has anyone seen the error, does it has something to do with Swig?
> thanks,
> Shawn
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
