[gdal-dev] Regarding using VRT to open a raw file
Dan Greve
grevedan at hotmail.com
Thu Jun 11 12:42:32 EDT 2009
I'm using the VRT schema to open a raw binary image file. I can successfully access the image data by creating a VRT file with the necessary metadata, and then perform GDALOpen using the filename of the VRT file. Is there a clean way to just create the VRT metadata file in memory, instead of having to create a VRT file on disk?
-- Dan Greve
-- Northrop Grumman Corp
-- Melbourne, FL
_________________________________________________________________
Lauren found her dream laptop. Find the PC that’s right for you.
http://www.microsoft.com/windows/choosepc/?ocid=ftp_val_wl_290
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090611/1cc225d3/attachment.html
