[gdal-dev] TIFFReadEncodedTile() failed
Even Rouault
even.rouault at mines-paris.org
Mon Jun 15 16:34:05 EDT 2009
Looks like your input image might be corrupted. You could confirm by running :
gdalinfo -checksum Av.MaxNDVI.2000.2009.Week.17.tif
If it still triggers the error but you believe the image is not corrupted, you
should try with a recent version of GDAL first and if it still persists, file
a ticket with a link to that image.
Le Monday 15 June 2009 21:15:28 Dillabough, Craig, vous avez écrit :
> Hi,
> I am trying to use GDAL to rescale/reproject a fairly large GeoTiff file
> (just over 1 GB). The image is 28800x9600 with 32 bit floating-point
> pixel values. I would like to reproject it, but for starters wanted to
> try rescaling it to 8 bits. When running gdal_translate as follows:
> gdal_translate -ot Byte -of GTiff -scale 0.0 1.0 0 255
> Av.MaxNDVI.2000.2009.Week.17.tif wk17.2000-09.8bit.tif
> I get the following message:
> Input file size is 28800, 9600
> 0Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in
> tag.
> ...10...20...30...40...50.ERROR 1:
> TIFFFillTile:Av.MaxNDVI.2000.2009.Week.17.tif
> : Read error at row 12288, col 2688; got 4088 bytes, expected 16384
> ERROR 1: TIFFReadEncodedTile() failed.
> ERROR 1: IReadBlock failed at X offset 193, Y offset 83
> ERROR 1: GetBlockRef failed at X block offset 193, Y block offset 83
> Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag.
> I don't think the error is specific to my particular rescale command.
> I've tried both gdal_translate to break up my image into smaller images,
> and gdalwarp to reproject the image (the original GeoTiff), and both
> generate a similar error. Perhaps it is the input file.
> In case it is of any use, gdalinfo produces the following output for the
> input file Av.MaxNDVI.2000.2009.Week.17.tif:
> Driver: GTiff/GeoTIFF
> Files: Av.MaxNDVI.2000.2009.Week.17.tif
> Av.MaxNDVI.2000.2009.Week.17.aux
> Av.MaxNDVI.2000.2009.Week.17.rrd
> Size is 28800, 9600
> Coordinate System is:
> PROJCS["User_Defined_Sinusoidal",
> GEOGCS["GCS_User_Defined",
> DATUM["User_Defined",
> SPHEROID["User_Defined_Spheroid",6371007.181,0.0]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],
> PROJECTION["Sinusoidal"],
> PARAMETER["False_Easting",0.0],
> PARAMETER["False_Northing",0.0],
> PARAMETER["Central_Meridian",0.0],
> UNIT["Meter",1.0]]
> Origin = (-10007554.677000004798174,6671703.118001982569695)
> Pixel Size = (231.656358263958310,-231.656358263958339)
> Metadata:
> AREA_OR_POINT=Area
> TIFFTAG_SOFTWARE=IMAGINE TIFF Support
> Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
> @(#)$RCSfile: etif.c $ $Revision: 1.10.1.9.1.9.2.11 $ $Date: 2004/09/15
> 18:42:01
> EDT $
> TIFFTAG_XRESOLUTION=1
> TIFFTAG_YRESOLUTION=1
> TIFFTAG_RESOLUTIONUNIT=1 (unitless)
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left (-10007554.677, 6671703.118) (180d 0'0.00"W, 60d 0'0.00"N)
> Lower Left (-10007554.677, 4447802.079) (117d29'11.96"W, 40d 0'0.00"N)
> Upper Right (-3335851.559, 6671703.118) ( 60d 0'0.00"W, 60d 0'0.00"N)
> Lower Right (-3335851.559, 4447802.079) ( 39d 9'43.99"W, 40d 0'0.00"N)
> Center (-6671703.118, 5559752.598) ( 93d20'36.35"W, 50d 0'0.00"N)
> Band 1 Block=64x64 Type=Float32, ColorInterp=Gray
> Min=0.000 Max=0.957
> Minimum=0.000, Maximum=0.957, Mean=0.191, StdDev=0.197
> Overviews: 7200x2400, 3600x1200, 1800x600, 900x300, 450x150, 225x75,
> 113x38
> Thank you for any help you can provide.
> Regards,
> Craig
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
