[gdal-dev] TIFFReadEncodedTile() failed
Dillabough, Craig
Craig.Dillabough at AGR.GC.CA
Mon Jun 15 15:15:28 EDT 2009
I am trying to use GDAL to rescale/reproject a fairly large GeoTiff file
(just over 1 GB). The image is 28800x9600 with 32 bit floating-point
pixel values. I would like to reproject it, but for starters wanted to
try rescaling it to 8 bits. When running gdal_translate as follows:
gdal_translate -ot Byte -of GTiff -scale 0.0 1.0 0 255
Av.MaxNDVI.2000.2009.Week.17.tif wk17.2000-09.8bit.tif
I get the following message:
Input file size is 28800, 9600
0Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in
tag.
...10...20...30...40...50.ERROR 1:
TIFFFillTile:Av.MaxNDVI.2000.2009.Week.17.tif
: Read error at row 12288, col 2688; got 4088 bytes, expected 16384
ERROR 1: TIFFReadEncodedTile() failed.
ERROR 1: IReadBlock failed at X offset 193, Y offset 83
ERROR 1: GetBlockRef failed at X block offset 193, Y block offset 83
Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag.
I don't think the error is specific to my particular rescale command.
I've tried both gdal_translate to break up my image into smaller images,
and gdalwarp to reproject the image (the original GeoTiff), and both
generate a similar error. Perhaps it is the input file.
In case it is of any use, gdalinfo produces the following output for the
input file Av.MaxNDVI.2000.2009.Week.17.tif:
Driver: GTiff/GeoTIFF
Files: Av.MaxNDVI.2000.2009.Week.17.tif
Av.MaxNDVI.2000.2009.Week.17.aux
Av.MaxNDVI.2000.2009.Week.17.rrd
Size is 28800, 9600
Coordinate System is:
PROJCS["User_Defined_Sinusoidal",
GEOGCS["GCS_User_Defined",
DATUM["User_Defined",
SPHEROID["User_Defined_Spheroid",6371007.181,0.0]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Sinusoidal"],
PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",0.0],
UNIT["Meter",1.0]]
Origin = (-10007554.677000004798174,6671703.118001982569695)
Pixel Size = (231.656358263958310,-231.656358263958339)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=IMAGINE TIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: etif.c $ $Revision: 1.10.1.9.1.9.2.11 $ $Date: 2004/09/15
18:42:01
EDT $
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-10007554.677, 6671703.118) (180d 0'0.00"W, 60d 0'0.00"N)
Lower Left (-10007554.677, 4447802.079) (117d29'11.96"W, 40d 0'0.00"N)
Upper Right (-3335851.559, 6671703.118) ( 60d 0'0.00"W, 60d 0'0.00"N)
Lower Right (-3335851.559, 4447802.079) ( 39d 9'43.99"W, 40d 0'0.00"N)
Center (-6671703.118, 5559752.598) ( 93d20'36.35"W, 50d 0'0.00"N)
Band 1 Block=64x64 Type=Float32, ColorInterp=Gray
Min=0.000 Max=0.957
Minimum=0.000, Maximum=0.957, Mean=0.191, StdDev=0.197
Overviews: 7200x2400, 3600x1200, 1800x600, 900x300, 450x150, 225x75,
113x38
Thank you for any help you can provide.
Regards,
Craig
