[gdal-dev] Build OGR with Oracle support
Mateusz Loskot
mateusz at loskot.net
Fri Jun 19 09:50:19 EDT 2009
Andreas Neumann wrote:
> /usr/bin/ld: warning: libnnz10.so, needed by
> /usr/local/lib/instantclient_10_2/libclntsh.so, not found (try using
> -rpath or -rpath-link)
The path above and the path below are different.
>> -L/home/fgs/fgs-dev/built/instantclient_11_1 -lc\
>> lntsh
Are you sure you configure against one version of Oracle stuff?
From what I can see, you have two versions.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
