[gdal-dev] Build OGR with Oracle support
Normand Savard nsavard at mapgears.com
Fri Jun 19 11:03:02 EDT 2009
Mateusz Loskot wrote:
> Andreas Neumann wrote:
>> /usr/bin/ld: warning: libnnz10.so, needed by
>> /usr/local/lib/instantclient_10_2/libclntsh.so, not found (try using
>>  -rpath or -rpath-link)
> The path above and the path below are different.
>>> -L/home/fgs/fgs-dev/built/instantclient_11_1 -lc\
>>> lntsh
> Are you sure you configure against one version of Oracle stuff?
> From what I can see, you have two versions.
Mateusz,
Maybe I misinterpreted Andreas' email but I think he's trying to compile
GDAL/OGR with OCI (Oracle Instantclient) outside of fgs-dev.  Can you
confirm Andreas?
Norm
