[gdal-dev] Build OGR with Oracle support
Andreas Neumann
a.neumann at carto.net
Sun Jun 21 15:55:39 EDT 2009
yes, my setup has nothing to do with fgs-dev
This other path maybe appeared from the original email I was answering,
but on my machine all the oracle instant client libraries are stored
under /usr/local/lib/instantclient_10_2/ and the header files under
/usr/local/lib/instantclient_10_2/sdk/
I will try again on Monday, maybe with also setting the PATH variable.
I will report back tomorrow.
Andreas
Normand Savard wrote:
> Mateusz Loskot wrote:
>> Andreas Neumann wrote:
>>> /usr/bin/ld: warning: libnnz10.so, needed by
>>> /usr/local/lib/instantclient_10_2/libclntsh.so, not found (try using
>>> -rpath or -rpath-link)
>> The path above and the path below are different.
>>>> -L/home/fgs/fgs-dev/built/instantclient_11_1 -lc\
>>>> lntsh
>> Are you sure you configure against one version of Oracle stuff?
>> From what I can see, you have two versions.
> Mateusz,
> Maybe I misinterpreted Andreas' email but I think he's trying to
> compile GDAL/OGR with OCI (Oracle Instantclient) outside of fgs-dev.
> Can you confirm Andreas?
> Norm
